Stack between a WS-2960S and a 2960X series
digital-network
Good morning,
I'd like to know if it is possible to make a stack between a WS-2960S and a 2960X series switches.
I'd like to know also if the stack card that is working now on a ws-2960S can be uses on a 2960X switch.
Thanks in advance for your help,
Cristiano Balestri
Digital Network Srl.
5 Replies 5
InayathUlla Sharieff
Yes u can stack thus two models.
Ref:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/white_paper_c11-728327.html
Hth
Thanks for your replies.
Do you know if I can use a stacking module that is currently installed on a 2690-s on a
2960-x? I mean, I have to replace a 2960-s stack member with a 2960-x, and I wanted
to know if I have to purchase an additional stacking module, or if I can re-use the one that
is on the 2960-s that has to be replaced.
Thanks for your help
Cristiano.
Christiano,
Please find anaswer:-
1) 2960-stack moudles fit only 2960s
2) 2960-x fit modules fit only 2960x
3) cables are the same
B-
Can we use FlexStack stacking modules with Cisco Catalyst 2960-X Series?
A. No. The form factors of  FlexStack-Plus and FlexStack modules are different. The FlexStack  stacking module cannot be used with the Cisco Catalyst 2960-X Series.  Similarly, the FlexStack-Plus module cannot be used with the Cisco  Catalyst 2960-S Series.
2-
C2960S-STACK - FlexStack hot-swappable stacking module
C2960X-STACK - FlexStack-Plus hot-swappable stacking module
CAB-STK-E-0.5M - FlexStack stacking cable with a 0.5 m length
CAB-STK-E-0.5M - FlexStack-Plus stacking cable with a 0.5 m length
Inayath
*******************Please do not forget to rate all usefull posts.***************
Hi Inayath,
thank you very much for your help.
Cristiano.
Reza Sharifi
Never done it, but according to the data sheet you can mix 2960x with 2960s as long as you have FlexStack-Plus module installed.
FlexStack-Plus is backward compatible with 2960-S and FlexStack. Mixing 2960-X and 2960-S members in a stack is supported. When the stack membership is mixed with 2960-X and 2960-S models, FlexStack-Plus falls back to FlexStack capabilities of 40Gbps stack bandwidth and four members maximum per stack.
Link:
