Stack issue of 3750x switches
mansuriadnan
    I have a stack of 8 switches in which 1st switch is master with priority 15.
    8th switch is secondary with 14 priority.
    but when Switch 1 fails then by default secondary should become master
    but in my case it doesnt happens, the whole stack gets down.
    So pls help why switchover redundancy is not happening
Leo Laohoo
How did you fail-over to secondary?
I mean, what method did you use to fail-over?
Its on priority based.
What method means?
What method means?
How did you made switch 1 fail?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Just wondering, does your original master have an IPService feature set license?  If so, does the intended secondary have it too?
