Showing results forĀ
Search instead forĀ
Did you mean:Ā
Stack Master placement in a switch stack ?
herve.leon
Level 2
Level 2
In the SBA (Smart Business Architecture) LAN Deployment Guide, I can read that when three or more switches are configured as a stack, the stack master should be configured on  a switch that does not have uplinks configured. (so in the middle of the stack).
I was wondering if there were any technical reasons to this design approach ??
Herve
Apurva Kulkarni
Hi Herve,
The uplink ports on the switch would be configured as trunk ports and would be carrying the traffic from all vlans. The stack master on a stack would be responsible for managing the stack and relay the information to all the members of the stack.
The following details explain the role of the stack master switch which will help us
The stack master controls the configuration and is the central point for  management. All Layer 2 protocol traffic (for example, VLAN Trunking Protocol  [VTP], Dynamic Trunking Protocol [DTP] , Cisco Discovery Protocol, Link Layer  Discovery Protocol [LLDP]) is forwarded to the master regardless of where the  protocol packet ingresses. The master will also transmit all Layer2 protocol  packets. If the egress interface is on another member, then the protocol packet  is passed from the master along the stack to the destination member.
The same  behavior is seen for management traffic. Simple Network Management Protocol  (SNMP), HTTP, Telnet, and Secure Shell (SSH) Protocol type of management traffic  is all forwarded to the master regardless of the ingress interface. The response  from the master is sent through the stack to the destination interface.
On  configuration changes, the stack master pushes a copy of the configuration to  every member. This way all members have a copy of the saved  configuration.
Stack upgrades occur on the master. The master pushes new  Cisco IOS Software images to all members. Each member stores a copy of the Cisco  IOS Software image on its local Flash.
Hence, if we configure the switch which has uplinks configured on it as the master in the stack, then it would cause an overhead on the master and may affect the performance of the stack or the uplink ports.
Hence it  is recommended to make the switch which does not contain the uplink ports as teh master in the stack.
Hope this would be helpful.
Apurva Kulkarni
Hi Herve,
thanks a lot Apurva for your explanations.
Herve
