How to capture packets and send to a sniffer
zzbronski
I have searched these forums but did not find anything on how to do this. I did this once several years ago but cannot remember how I did it. What I do remember is that I used the "debug" command and SPAN on the 6509 and the designated port where all the traffic passes through to the router and then pointed to the IP of the sniffer. I am using a Cisco 6509(core switch) and 3845 (WAN router) and a Fluke Optiview II and snmp.
hobbe
Level 7
Level 7
You use the monitor session ...... command
Here is a link describing how you handle it on most of the cisco switches.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Good luck
hobbe
Level 7
Level 7
Good luck
