Stack of two SG550X
Arazu
Can I use GE1 and GE2 ports to stack two switches?
If so in what way?
I want to use ports XG1-4 for something else.
you need 2 XG ports for stack.
Good luck
KB
no, only 10G ports can use to do stcaking.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/550xseries/quick_start/guide/550xseries-QSG-en-US.pdf
Good luck
KB
It is  possible to use only one XG port to create a stack?
When i try use only one XG i recive error : In order to enable stacking, at least two stacking ports must be selected.
Good luck
KB
