Stack Power Conflict, but where? 3750
lowfell
Level 3
Level 3
the error messages are sayin Power conflict, but i can't see where that is? any ideas please?
3750X-CallFlex-111#sh stack-power
Power stack name: Powerstack-2
Stack mode: Power sharing
Stack topology: Ring
Switch 1:
Power budget: 223
Low port priority value: 21
High port priority value: 12
Switch priority value: 3
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: acf2.c573.d180
Neighbor on port 2: acf2.c56c.da00
Switch 5:
Power budget: 223
Low port priority value: 20
High port priority value: 11
Switch priority value: 2
Neighbor on port 1: b000.b4df.4f80
Neighbor on port 2: acf2.c575.7f00
Switch 2:
Power budget: 223
Low port priority value: 19
High port priority value: 10
Switch priority value: 1
Port 2 status: Not connected
Neighbor on port 1: acf2.c575.7f00
Neighbor on port 2: 0000.0000.0000
Switch 4:
Power budget: 223
Low port priority value: 22
High port priority value: 13
Port 1 status: Not connected
Neighbor on port 1: 0000.0000.0000
Neighbor on port 2: acf2.c573.d180
Power stack name: Powerstack-3
Stack mode: Power sharing strict
Stack topology: Standalone
Switch 3:
Power budget: 223
Switch priority value: 4
Port 1 status: Shut
Port 2 status: Shut
3750X-CallFlex-111#
Jan 5 11:42:04: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 1's power stack has conflicting power priorities
3750X-CallFlex-111#
Jan 5 11:42:35: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 4's power stack has conflicting power priorities
3750X-CallFlex-111#
Jan 5 11:43:05: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
3750X-CallFlex-111#
Jan 5 11:44:05: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 1's power stack has conflicting power priorities
3750X-CallFlex-111#
Jan 5 11:44:35: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 4's power stack has conflicting power priorities
3750X-CallFlex-111#
Jan 5 11:45:06: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
Jan 5 11:46:05: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 1's power stack has conflicting power priorities
Stackwise all looks good, make necessary power priority change as suggested, and reboot the member only (should fix the issue)
if you get chance bounce the whole stack, if you get maintenance window, Looks like this hospital switch, due to CV19 its hard to get downtime.
BB
16 Replies 16
balaji.bandi
just the priority value :
Switch 1:
Power budget: 223
Switch 5:
Power budget: 223
Switch 2:
Power budget: 223
Switch 4:
Power budget: 223
Switch 3:
Power budget: 223
Port 1 status: Shut
Port 2 status: Shut
Make sure do this change in Maintenance window, if still has issue
post show version, show switch, show stack- information
BB
how do you change these priority values? as we hard coded these yesterday with
switch 1 15
switch 2 14
switch 3 12 etc...... ?
Hello all. he said he's changed this, but still get the messages,
1 do you need to reboot the stack to implement this?
2. what are the implications of just leaving it,  is it purely cosmetic?
balaji.bandi
after changing post the same out put to understand. some time it do required to reboot to take effective some config.
Leaving like that the power not going to distribute as expected, when the power failure take place, it will be disaster for the PoE devices.
BB
Here are the latest logs. this doesn't seem to make any sense as it refers to switch 5 ? and When you run the show Power it saying there is actually two stacks instead of one stack of five?
Switch 3:
Power budget: 320
Port 1 status: Shut
Port 2 status: Shut
Switch 1:
Power budget: 223
Switch 5:
Power budget: 223
Switch 2:
Power budget: 223
Port 2 status: Shut
Switch 4:
Power budget: 223
Port 1 status: Shut
3750X-CallFlex-111#
Jan 6 10:42:44: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:43:16: %LINK-3-UPDOWN: Interface GigabitEthernet5/0/18, changed state to up
Jan 6 10:43:18: %LINK-3-UPDOWN: Interface GigabitEthernet5/0/18, changed state to down
Jan 6 10:43:21: %LINK-3-UPDOWN: Interface GigabitEthernet5/0/18, changed state to up
Jan 6 10:43:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5/0/18, changed state to up
Jan 6 10:43:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5/0/18, changed state to down
Jan 6 10:43:32: %LINK-3-UPDOWN: Interface GigabitEthernet5/0/18, changed state to down
Jan 6 10:43:36: %LINK-3-UPDOWN: Interface GigabitEthernet5/0/18, changed state to up
Jan 6 10:43:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5/0/18, changed state to up
Jan 6 10:43:44: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:44:44: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:45:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:46:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:47:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:48:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:49:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:50:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:51:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:52:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:53:45: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:54:38: %LINK-3-UPDOWN: Interface GigabitEthernet4/0/8, changed state to up
Jan 6 10:54:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0/8, changed state to up
Jan 6 10:54:46: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:54:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0/8, changed state to down
Jan 6 10:54:48: %LINK-3-UPDOWN: Interface GigabitEthernet4/0/8, changed state to down
Jan 6 10:54:52: %LINK-3-UPDOWN: Interface GigabitEthernet4/0/8, changed state to up
Jan 6 10:54:53: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0/8, changed state to up
Jan 6 10:55:46: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:56:46: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
Jan 6 10:57:06: %SEC-6-IPACCESSLOGS: list 99 permitted 172.16.105.199 2 packets
Jan 6 10:57:46: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 5's power stack has conflicting power priorities
3750X-CallFlex-111#
However if you look at the config the
Please post the full config along with below output :
show switch
show switch stack-ports
BB
Hello. the customer made dsome changes which are probably wrong yesterday The stack hasn't been rebooted yet.
#stack-power switch 3
#stack Powerstack-2
%The change may not take effect until the entire data stack is reloaded
3750X-CallFlex-111#sh run
Building configuration...
Current configuration : 147941 bytes
version 12.2
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname 3750X-CallFlex-111
boot-start-marker
boot-end-marker
enable secret 5 $1$BPGJ$DZL/u.YkWFNYv4jmR3/EX0
username backup privilege 2 secret 5 $1$POls$e4AMQ4l5sXLG7JLlCJUUB1
username CiscoCAA privilege 2 secret 5 $1$5/JE$MsTMZoeTPFrTnumThjHdN.
username LocalTemp privilege 15 password 7 0615092F787B1B5456360A
aaa new-model
aaa authentication login default group radius local
aaa authentication enable default enable
aaa authentication dot1x default group radius none
aaa authorization exec default group radius local
aaa authorization network default group radius
aaa session-id common
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 0:00
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
switch 3 provision ws-c3750x-48
switch 4 provision ws-c3750x-48
switch 5 provision ws-c3750x-48
system mtu routing 1500
no ip source-route
ip icmp rate-limit unreachable 10
ip cef load-sharing algorithm universal B27D2F8F
no ip domain-lookup
ip domain-name yas.nhs.uk
ip host nww.advhc.net 10.200.123.120
stack-power stack Powerstack-2
stack-power stack Powerstack-3
stack Powerstack-2
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-3312811776
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3312811776
revocation-check none
rsakeypair TP-self-signed-3312811776
crypto pki certificate chain TP-self-signed-3312811776
certificate self-signed 01
30820255 308201BE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33333132 38313137 3736301E 170D3138 30353039 31363237
30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33313238
31313737 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C9A7 99E762A9 89DFE52D E54EB494 E672183B 6B325AAE 46EA776A 29102459
3B1A7942 8A57054E 219F9370 D24E6A8F D9DC45AD D4AC7B35 DA34360A 00A36917
CAFBE781 78885731 89117AF9 004CB434 356BE9B8 B3D0E816 9A85DB14 4628DA9D
8C013258 78EB9CF1 81545F35 14B62BFD 683D6FC0 2F0A3549 54BC0FA0 B440E910
9A490203 010001A3 7D307B30 0F060355 1D130101 FF040530 030101FF 30280603
551D1104 21301F82 1D333735 30582D43 616C6C46 6C65782D 3131312E 7961732E
6E68732E 756B301F 0603551D 23041830 168014AC A9613177 DFBC3014 6936060B
8F4493B6 04B29C30 1D060355 1D0E0416 0414ACA9 613177DF BC301469 36060B8F
4493B604 B29C300D 06092A86 4886F70D 01010405 00038181 003F1EF1 34431DA5
DE7423A9 4933DCF9 B7EFE984 06A076EC 016D6BE7 6BAE55B5 0D162A17 BF4D8053
6E1786E6 82E913BA 1E4D2DC3 1F319ECA 7AA71368 851EF3E6 F9D9832A D697B487
10D47DCB A79F9BFE 039A8C0D 34E570B7 1F91E3BF 61DE0B7A 2924F058 69D0D97B
E37E43C2 59B70A47 DE476FC8 80A09A1A 0BDE88AD 11A2C1B7 0D
quit
license boot level ipbase switch 4
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast
spanning-tree backbonefast
auto qos srnd4
errdisable recovery cause udld
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause storm-control
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
vlan internal allocation policy ascending
ip tcp synwait-time 13
class-map match-all SQLTraffic
match access-group 151
class-map match-all CADSQL
match access-group name CADSQL
class-map match-all CAD-Replication
match access-group name CAD-Replication
class-map match-all CALL-SIGNALLING
match ip dscp cs5
class-map match-all RDP
match access-group name RDP
class-map match-all Adastra-111
match access-group name Adastra-111
class-map match-all CAD-File
match access-group name CAD-File
class-map match-any VOICE
match ip dscp ef
class-map match-all QOSTest
match access-group name QOSTest
policy-map YAS-Important-Traffic
class VOICE
set dscp ef
class SQLTraffic
set dscp af21
class QOSTest
set dscp af21
class CADSQL
set dscp af21
class CAD-File
set dscp af22
class CAD-Replication
set dscp af21
class RDP
set dscp af21
class CALL-SIGNALLING
set dscp cs5
class Adastra-111
set dscp af21
class class-default
set dscp default
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport access vlan 20
switchport mode access
switchport port-security maximum 5
switchport port-security aging time 5
switchport port-security violation protect
srr-queue bandwidth share 10 30 35 5
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
storm-control broadcast level 5.00
storm-control multicast level 5.00
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input YAS-Important-Traffic
interface GigabitEthernet1/0/2
switchport access vlan 21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/6
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/7
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/8
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/9
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/11
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/13
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/14
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/15
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/16
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/17
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/18
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/19
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/20
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/25
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/27
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/28
switchport access vlan 22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/29
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/30
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/31
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/32
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/33
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/34
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/35
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/36
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/37
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/38
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/39
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/40
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/41
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/42
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/43
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/44
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/45
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/46
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/47
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet1/0/48
switchport mode trunk
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
interface GigabitEthernet1/1/1
description Connection to 3750-CallFlex-Server
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface GigabitEthernet2/0/1
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/2
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/6
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/7
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/8
description EOC Printer
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/9
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/11
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/13
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/14
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/15
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/16
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/17
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/18
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/19
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/20
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/25
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/27
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/28
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/29
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/30
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/31
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/32
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/33
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/34
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/35
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/36
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/37
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/38
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/39
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/40
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/41
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/42
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/43
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/44
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/45
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/46
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/47
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/0/48
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface GigabitEthernet3/0/1
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/2
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/6
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/7
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/8
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/9
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/11
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/13
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/14
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/15
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/16
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/17
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/18
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/19
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/20
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/25
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/27
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/28
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/29
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/30
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/31
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/32
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/33
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/34
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/35
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/36
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/37
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/38
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/39
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/40
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/41
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/42
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/43
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/44
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/45
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/46
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/47
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/0/48
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet3/1/1
interface GigabitEthernet3/1/2
interface GigabitEthernet3/1/3
interface GigabitEthernet3/1/4
interface TenGigabitEthernet3/1/1
interface TenGigabitEthernet3/1/2
interface GigabitEthernet4/0/1
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/2
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/6
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/7
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/8
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/9
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/11
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/13
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/14
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/15
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/16
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/17
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/18
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/19
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/20
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/25
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/27
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/28
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/29
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/30
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/31
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/32
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/33
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/34
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/35
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/36
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/37
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/38
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/39
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/40
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/41
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/42
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/43
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/44
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/45
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/46
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/47
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/0/48
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet4/1/1
interface GigabitEthernet4/1/2
interface GigabitEthernet4/1/3
interface GigabitEthernet4/1/4
interface TenGigabitEthernet4/1/1
interface TenGigabitEthernet4/1/2
interface GigabitEthernet5/0/1
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/2
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/6
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/7
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/8
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/9
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/11
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/13
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/14
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/15
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/16
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/17
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/18
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/19
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/20
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/21
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/22
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/25
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/27
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/28
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/29
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/30
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/31
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/32
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/33
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/34
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/35
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/36
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/37
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/38
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/39
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/40
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/41
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/42
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/43
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/44
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/45
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/46
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/47
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/0/48
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
interface GigabitEthernet5/1/1
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
interface GigabitEthernet5/1/2
interface GigabitEthernet5/1/3
interface GigabitEthernet5/1/4
interface TenGigabitEthernet5/1/1
interface TenGigabitEthernet5/1/2
interface Vlan1
no ip address
interface Vlan501
ip address 192.168.97.2 255.255.255.0
ip default-gateway 192.168.97.1
ip classless
no ip http server
no ip http secure-server
ip access-list extended Adastra-111
permit tcp any host 10.200.123.120
permit tcp host 10.200.123.120 any
ip access-list extended CAD-File
permit tcp any host 172.16.101.27
permit tcp host 172.16.101.27 any
permit tcp any host 10.144.198.152
permit tcp host 10.144.198.152 any
ip access-list extended CAD-Replication
permit tcp any host 10.144.198.152 eq 5022
permit tcp any host 172.16.101.30 eq 5022
permit tcp host 10.144.198.152 eq 5022 any
permit tcp host 172.16.101.30 eq 5022 any
ip access-list extended CADSQL
permit tcp any host 10.144.198.152 eq 1433
permit tcp host 10.144.198.152 eq 1433 any
permit tcp any host 172.16.101.30 eq 1433
permit tcp host 172.16.101.30 eq 1433 any
ip access-list extended QOSTest
permit ip host 192.168.97.1 host 172.16.105.129
permit ip host 172.16.105.129 host 192.168.97.1
ip access-list extended RDP
permit tcp any 172.16.101.0 0.0.0.255 eq 3389
permit tcp 172.16.101.0 0.0.0.255 eq 3389 any
permit tcp any 10.144.198.0 0.0.0.255 eq 3389
permit tcp 10.144.198.0 0.0.0.255 eq 3389 any
ip sla 5
tcp-connect 10.200.123.120 443 source-ip 192.168.97.2 source-port 1000 control disable
timeout 5000
frequency 10
ip sla schedule 5 life forever start-time now
logging trap notifications
logging 172.16.105.145
logging 172.16.105.143
access-list 98 permit 172.16.105.199
access-list 98 remark SNMP Access List
access-list 98 permit 172.16.105.145
access-list 98 permit 172.16.105.143
access-list 98 permit 172.16.103.120
access-list 98 permit 172.16.120.120 log
access-list 99 permit 172.16.105.199 log
access-list 99 permit 172.16.99.203 log
access-list 99 permit 172.16.105.131 log
access-list 99 permit 172.16.105.130 log
access-list 99 permit 172.16.105.143 log
access-list 99 permit 10.144.202.11 log
access-list 99 permit 172.16.105.161 log
access-list 99 permit 172.16.105.160 log
access-list 99 permit 172.16.105.85 log
access-list 99 permit 172.16.120.120 log
access-list 99 permit 172.16.113.25 log
access-list 151 permit tcp any host 10.144.198.155 eq 1433
access-list 151 permit tcp any host 172.16.101.30 eq 1433
access-list 151 permit tcp host 10.144.198.155 eq 1433 any
access-list 151 permit tcp host 172.16.101.30 eq 1433 any
access-list 151 deny ip any any
snmp-server group yasmonv3 v3 priv notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F
snmp-server group yasmonv3 v3 priv context vlan- notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F
snmp-server community yasmon RO 98
snmp-server chassis-id 3750X-CallFlex-111
snmp-server host 172.16.105.245 version 3 priv infrastructure
radius-server host 172.16.120.15 auth-port 1645 acct-port 1646
radius-server host 172.16.120.16 auth-port 1645 acct-port 1646
radius-server key 7 0723205E1A081F155D
no vstack
banner exec ^C
Y O R K S H I R E A M B U L A N C E S E R V I C E
DEVICE DETAILS
Hostname: 3750X-CallFlex-111
Device: Stack of Catalyst 3750x 5 x 48 port 10/100
^C
banner motd ^C
THIS DEVICE IS PART OF A
PRIVATE NETWORK
* Unauthorised access or use of this equipment *
* is prohibited and constitutes an offence *
* under the Computer Misuse Act 1990. *
* If you are not authorised to use this *
* system, terminate this session now. *
^C
line con 0
exec-timeout 5 0
logging synchronous
login authentication localusers
line vty 0 4
access-class 99 in
exec-timeout 30 0
logging synchronous
length 0
transport input ssh
line vty 5 15
access-class 99 in
exec-timeout 30 0
logging synchronous
transport input ssh
ntp clock-period 36027205
ntp peer 192.168.99.1 prefer
ntp peer 172.16.101.20 prefer
end
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#sh switch stack-ports
Switch # Port 1 Port 2
1 Ok Ok
2 Ok Ok
3 Ok Ok
4 Ok Ok
5 Ok Ok
Hello and thank you again. here are the changeds he made yesterday
#stack Powerstack-2
here is the config
! Last configuration change at 12:34:07 GMT Tue Jan 5 2021 by kiren.solomon.admin
! NVRAM config last updated at 12:33:53 GMT Tue Jan 5 2021 by adrian.wallis
version 12.2
no service pad
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
no ip domain-lookup
ip domain-name
ip host10.200.123.120
stack Powerstack-2
mls qos
quit
archive
log config
logging enable
logging size 200
hidekeys
auto qos srnd4
match ip dscp cs5
match ip dscp ef
class VOICE
set dscp ef
class SQLTraffic
set dscp af21
class QOSTest
set dscp af21
class CADSQL
set dscp af21
class CAD-File
set dscp af22
set dscp af21
class RDP
set dscp af21
set dscp cs5
class Adastra-111
set dscp af21
class class-default
set dscp default
no ip address
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
no cdp enable
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
interface Vlan1
no ip address
interface Vlan501
ip classless
no ip http server
ip sla 5
timeout 5000
frequency 10
no vstack
banner exec ^C
DEVICE DETAILS
^C
banner motd ^C
PRIVATE NETWORK
^C
line con 0
exec-timeout 5 0
logging synchronous
line vty 0 4
access-class 99 in
exec-timeout 30 0
logging synchronous
length 0
transport input ssh
line vty 5 15
access-class 99 in
exec-timeout 30 0
logging synchronous
transport input ssh
end
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
3750X-CallFlex-111#
1 Ok Ok
2 Ok Ok
3 Ok Ok
4 Ok Ok
5 Ok Ok
can you post also output.
show switch
show switch stack-ring speed
show switch stack-ports summary
here is the document :
https://www.slideshare.net/irisdan/cisco-3750-x-series-switchescisco-stack-power-efficient-use-of-power
BB
There you go
3750X-CallFlex-111#sh switch stack-ring speed
Stack Ring Speed : 32G
Stack Ring Configuration: Full
Stack Ring Protocol : StackWisePlus
3750X-CallFlex-111#sh switch stack-ports summary
Switch#/ Stack Neighbor Cable Link Link Sync # In
Port# Port Length OK Active OK Changes Loopback
Status To LinkOK
1/1 OK 2 50 cm Yes Yes Yes 2 No
1/2 OK 5 1 m Yes Yes Yes 1 No
2/1 OK 3 50 cm Yes Yes Yes 2 No
2/2 OK 1 50 cm Yes Yes Yes 2 No
3/1 OK 4 50 cm Yes Yes Yes 1 No
3/2 OK 2 50 cm Yes Yes Yes 1 No
4/1 OK 5 50 cm Yes Yes Yes 1 No
4/2 OK 3 50 cm Yes Yes Yes 1 No
5/1 OK 1 1 m Yes Yes Yes 1 No
5/2 OK 4 50 cm Yes Yes Yes 2 No
balaji.bandi
This Looks ok, still did not orginal information let me try again
output of
#show switch
BB
Apologies.
Switch/Stack Mac Address : acf2.c575.7f00
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master acf2.c575.7f00 15 1 Ready
2 Member acf2.c56c.da00 14 1 Ready
3 Member 44d3.ca00.a700 13 1 Ready
4 Member b000.b4df.4f80 12 1 Ready
5 Member acf2.c573.d180 11 1 Ready
Stackwise all looks good, make necessary power priority change as suggested, and reboot the member only (should fix the issue)
if you get chance bounce the whole stack, if you get maintenance window, Looks like this hospital switch, due to CV19 its hard to get downtime.
BB
