Stack Power mode on 3750
nilesh_sawant
I have stacked two WS-C3750X-48T-S as well as using stack-power cable. I have configured the stack-power mode in redundant then also it's show as 'power sharing' when checked using show stack-power command. Any idea why so ?
Below is the configuration
stack-power stack CSB-STACK-POWER
 mode redundant
stack-power switch 1
stack-power switch 2
------------------ show version ------------------
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 26-Jun-13 09:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
KU-CSB-CSW uptime is 5 hours, 57 minutes
System restarted at 11:17:53 kabul Thu Feb 19 2015
System image file is "flash:/c3750e-universalk9-mz.122-55.SE8/c3750e-universalk9-mz.122-55.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48 (PowerPC405) processor (revision Q0) with 262144K bytes of memory.
Processor board ID FDO1829Z1B3
Last reset from power-on
11 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : CC:D8:C1:28:20:00
Motherboard assembly number     : 73-12552-11
Motherboard serial number       : FDO18290TU7
Model revision number           : Q0
Motherboard revision number     : B0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO18290LHK
System serial number            : FDO1829Z1B3
Top Assembly Part Number        : 800-31326-09
Top Assembly Revision Number    : E0
Version ID                      : V06
CLEI Code Number                : CMMPN00DRA
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(55)SE8           C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48       12.2(55)SE8           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 5 hours, 57 minutes
Base ethernet MAC Address       : 7C:0E:CE:86:DB:00
Motherboard serial number       : FDO18290TNB
Daughterboard serial number     : FDO18290G5K
System serial number            : FDO1829Z18M
Top assembly part number        : 800-31326-09
Top assembly revision number    : E0
Version ID                      : V06
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
------------------ show stack-power ------------------
Power stack name: CSB-STACK-POWER
    Stack mode: Power sharing
    Stack topology: Ring
    Switch 1:
        Power budget: 223
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: 7c0e.ce86.db00
        Neighbor on port 2: 7c0e.ce86.db00
    Switch 2:
        Power budget: 223
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Neighbor on port 1: ccd8.c128.2000
        Neighbor on port 2: ccd8.c128.2000
Nilesh
What PSUs do you have?
Do you have enough power on a single box to run both switches?
