05-01-2024 03:04 AM
Hello Everyone,
Need to confirm if we require any license or our switch is capable for SVL configuration.
Model- Cisco C9407R
We have below license on the switch. Please let me know it is ok or not for SVL config.
#sh license summary
License Usage:
License Entitlement Tag Count Status
network-advantage (advantagek9-C9400) 1 IN USE
dna-advantage (dna_advantage-C9400) 1 IN USE
05-01-2024 03:53 AM
yes network advantage good enough for you to build SVL
Note: StackWise Virtual is supported on all Catalyst 9k Platforms with Network Advantage License only
05-02-2024 06:27 AM
Cisco Stack Wise Virtual is supported on CiscoCatalyst9400 SeriesSupervisor1 Module(C9400-SUP-1) and Cisco Catalyst9400 SeriesSupervisor1XL Module(C9400-SUP-1XL).
The feature requires a special, additional license,C9400-SUP-UPG-LIC=license with CiscoCatalyst9400 SeriesSupervisor1 Module(C9400-SUP-1).
As per my show inventory we are using C9400-SUP-1 so do we need to get C9400-SUP-UPG-LIC= lic ?
05-02-2024 08:34 AM
yes if you have that sup card - that what mentioned other URL i have posted , also check the version of code you running any caveats of that version.
Catalyst 9400 can be deployed with all types of supervisor modules but SUP-1 module requires an additional License for StackWise virtual configuration. The in-chassis standby Supervisors if available will be powered-off by the system
