05-08-2023 09:16 AM
Hi all,
I have two 9200 switches stacked and would like to connect teamed nic ports of a server. I have the interfaces configured in LaCP and on the server side also I have teamed ports using LaCP . The issue is that one nic card is showing 1G speed while the other is showing 100M.
Can someone please explain why this is happening and if this is normal?
05-08-2023 09:36 AM
- Are you sure that the interfaces at the server side are operating normally ?
M.
05-08-2023 09:41 AM
Thanks for the response,yes they are working fine.
The switch independent configuration works fine shows 1G on both interfaces but the issue is when switches are stacked.
05-08-2023 09:55 AM
- Check logs on the switches (both) when these connections are made ; same on sever, like for instance on Windows use eventvwr and look for networking events
M.
05-08-2023 10:24 AM
Can you post "sh run" and "sh etherchannel summary" from the stack? Also, are you connecting the stack to VM switches?
05-09-2023 07:09 AM
Hello everyone,
A summary of the steps I tried:
1.set the speed of the port to 1G on the switch and server. That didn't help,the interface on the server for disconnected.
2.Upon checking sh int I realised one of the ports are suspended,not sure why.
Attached are the ether channel summary and the sh int details of both ports that are connected to the server. The port channel summary has also been included.
The server is windows based and I have selected LACP in the teaming drop down.
Any help would be highly appreciated.
05-09-2023 07:25 AM
Can you post the output of "sh run" or show run interface g1/0/5 and 2/0/9?
Members in this channel: Gi2/0/9
The PO has only one member and that is 2/0/9
05-09-2023 07:42 AM
Attached are the show interface outputs.
I've also attached the log that is displayed when the teamed ports are connected to the switch.
In my observation one port has speed of 1G and the other goes into 100M. Everytime I disconnect and reconnect the port that has 1G changes.
05-09-2023 08:08 AM
Yes, the issue is with 1/05, as it shows it being 100Mb and not Gig, and that is causing mismatch on the PO. For testing, can you try a different interface e.g.,. 1/0/6 or 1/0/7?
Also, one more output "sh run int po3"
05-09-2023 08:11 AM
Thank you for the suggestions @Reza Sharifi .
I did try that as well, the issue persists if I connect the second patch cord to any of the ports on the stacked switch.
If I connect it to a completely different switch and set the teaming as switch independent both ports work on 1G each.
05-09-2023 08:57 AM
Thanks for the info! This maybe a software bug if it happens with all the ports on that first switch in the stack.
Can you try one more thing:
delete po3 completely and take the physicals ports 1/0/5 and 2/0/9 out of PO3. So, no PO at all. Now, follow these steps and create a new PO.
Config t
Interface gi2/0/9
chrannel-grpup 10 mode active
same for 1/0/5
This config above should create PO 10 for you.
Now, go to PO 10 interface
interface PO10
no sh
and now look at the PO summary and see if all interfaces are up.
05-09-2023 08:39 AM
05-09-2023 03:44 PM
its shows as suspended due to mismatch of speed - ?
05-09-2023 07:19 AM
To add to the above points,on the server side there is an error that states LACP negotiation failed.
05-08-2023 10:41 AM
hardcode the speed under the PO
may be the port member is 1G but the PO still have speed 100M
