Stacking 2960S and X switches
Jared McPhail
What is the recommended version of IOS to be used for stacking 2960S and 2960X switches?
When you stack 2960S and X you need to set to 10 gbps the stack ports
In a mixed stack of Catalyst 2960-X and 2960-S switches, you must set the stack port speed to 10 Gbps. This task is required in a mixed stack configuration and must be run on a Catalyst 2960-X switch in the switch stack before you add a 2960-S switch to the stack. Otherwise, the switches will not stack.
SUMMARY STEPS
1.    configure terminal
2.    switch stack port-speed 10
3.    end
4.    copy running-config startup-config
5.    reload
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.html#task_E4FC5C32789B42B19C79AB60E126BEC9
15 Replies 15
Leo Laohoo
Look at the Cisco download page and see what IOS version for the 2960S can also be found in the 2960X.
I've done that in the past which meant downgrading my X to an IOS version supported by the S, and even then they wouldn't stack. They didn't recognize one another.
Post the complete output to the command "sh version".
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 16-Dec-16 20:58 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 19 minutes
System image file is "flash:/c2960s-universalk9-mz.152-2.E6/c2960s-universalk9-mz.152-2.E6.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision G0) with 131072K bytes of memory.
Processor board ID FOC1732Y3CZ
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E8:ED:F3:1E:9F:80
Motherboard assembly number     : 73-11907-09
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC17320Z6A
Power supply serial number      : LIT17221N5D
Model revision number           : G0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48LPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC173211QB
System serial number            : FOC1732Y3CZ
Top Assembly Part Number        : 800-30937-04
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMGZ00ARD
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model                     SW Version            SW Image
*    2 52    WS-C2960S-48LPS-L         15.2(2)E6             C2960S-UNIVERSALK9-M
Configuration register is 0xF
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
Compiled Fri 16-Dec-16 21:27 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(2r)E1, RELEASE SOFTWARE (fc1)
Switch uptime is 23 minutes
System restarted at 16:26:11 UTC Wed Feb 15 2017
System image file is "flash:/c2960x-universalk9-mz.152-2.E6/c2960x-universalk9-mz.152-2.E6.bin"
export@cisco.com.
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision F0) with 524288K bytes of memory.
Processor board ID FCW1852B13D
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
Base ethernet MAC Address       : 68:9C:E2:96:93:00
Motherboard assembly number     : 73-15964-03
Power supply part number        : 341-0527-01
Motherboard serial number       : FOC185174K8
Power supply serial number      : DCB184760KY
Model revision number           : F0
Motherboard revision number     : B0
Model number                    : WS-C2960X-48FPD-L
Daughterboard assembly number   : 73-14200-03
Daughterboard serial number     : FOC18512W0V
System serial number            : FCW1852B13D
Top Assembly Part Number        : 800-41461-03
Version ID                      : V04
CLEI Code Number                : CMMTR00BRA
Hardware Board Revision Number  : 0x12
*    1 52    WS-C2960X-48FPD-L         15.2(2)E6             C2960X-UNIVERSALK9-M
Can I see the "sh version" when the two switches are stacked?
I'm interested to see the error messages when they are stacked.
That is them stacked. I have to connect to each switch through the console port to get the "sh ver" off of each switch.  They're not stacking, even though I have them connected up to each other. That's the problem I don't error message.
Ok, can I see the complete output to the command "sh switch d"?
This is the output from the 2960X
Switch/Stack Mac Address : 689c.e296.9300
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 689c.e296.9300     1      4       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1       Down       Down             None     None
This is the output from the 2960S
*2       Master e8ed.f31e.9f80     1      5       Ready
  2       Down       Down             None     None
Hold on ... Exactly how are the two switches connected to each other?
The output above tells me the stacking modules (if there even is one) isn't even connected.  Not even a single cable?
Are we still talking about connecting the two using FlexStack technology (using the stacking module at the back of the switch) or Switch Stacking (connecting using Ethernet) or Cisco's Horizontal Stacking?
Picture of stacking cables connecting the switches together.
That is weird.  I've never seen a behaviour like that before.
Wait a second ... console into one of them.  Reboot the switch.  I want to see each of them doing a boot-up.  I think one of the stacking module is throwing up a tantrum about the module being a counterfeit (not true).
SUMMARY STEPS
3.    end
5.    reload
Jared McPhail
Thanks Alan that worked. They stacked as soon as I set the 2960X stack port speed to 10.
