Stacking 3750's
newbie
Level 3
Level 3
I am planning on stacking 3 3750's. Do all need to have the same IOS? If one has a different IOS is there a command to have the master load his ios onto the switch with the different ios.
Collin Clark
Switches with the same major version number but with a different minor version number as the stack master are considered partially compatible.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#softcomp
Hope that helps.
Leo Laohoo
Working with the Cisco IOS File System, Configuration Files, and Software Images
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swiosfs.html#wp1257143
Hope this helps.
bretjaquish
Level 6
Level 6
