Stacking 3750 switches port numbering
swamy105
HOW Master switches in stack numbering the port? is it based on priority ?
anybody can give explanation for this .. I would be grateful to you
2 Accepted Solutions
thestagman
Your master switch port numbering will be 1/0/1-48, the next switch in the stack will be 2/0/1-48 and the third 3/0/1-48 and so on.
Hopefully you should see a pattern emerging here..
The above assumes that your switches are the 48 port variety
The switch stack numbering are based on priority (which you can alter)
For info and CLI commands see:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdee3.html#1044402
This section contains this configuration information:
Default Switch Stack Configuration
Assigning a Stack Member Number
Setting the Stack Member Priority Value
Accessing the CLI of a Specific Stack Member
If this is of use for you, please rate it.
thestagman
