Stacking a 3560
sgilfrin1
Community Member
I've just received a ws-c3560g-48ps-s and noticed the lack of stack ports on the back, I thought all the 3560's were stackable, if so how the hell do you make it stackable? Guessing using the sfp.
5 Replies 5
Jon Marshall
sgilfrin1 wrote:
I've just received a ws-c3560g-48ps-s and noticed the lack of stack ports on the back, I thought all the 3560's were stackable, if so how the **** do you make it stackable? Guessing using the sfp.
Steve
The 3750 series switches are stackable, not the 3560 switches. You can as you say interconnect them using the SFP cable.
Jon
We have received two 3560 switches with SFP modules. how do we stack them together, please help
It was just explained above that you can't stack with 3560's 😛 You will have to manage them separately.
glen.grant
  As Jon said the 3560's are not stackable .  You will need a separate ip address to manage each switch . You can use gbic patch cables to tie them together thru ports 49-52 .
Leo Laohoo
For layer 2 switches, only the 2960S and 2975 are stackable.  3750/3750E/3750X is the only model which support stacking.
Another method is to use Switch Clustering.
System Requirements to Implement Switch Clustering Technology
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_tech_note09186a008011766b.shtml
Configuring and Analyzing Clustering on Catalyst Fixed Configuration Switches
http://www.cisco.com/en/US/customer/products/hw/switches/ps607/products_tech_note09186a00801347f8.shtml
