01-06-2013
12:00 AM
- last edited on
03-25-2019
04:23 PM
by
ciscomoderator
Hello Friends,
Can you pls sugggest that can we done stacking in between below two switches
One Switch:
------------------ show inventory ------------------
NAME: "1", DESCR: "WS-C3750X-12S"
PID: WS-C3750X-12S-S , VID: V03 , SN: FDO1649P1FL
Hardware cisco WS-C3750X-12S
System image file is "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Second Switch
NAME: "1", DESCR: "WS-C3750X-24S"
PID: WS-C3750X-24S-S , VID: V01 , SN: FDO1617Z1CE
Ganesh Gupta
01-06-2013 12:04 AM
Yes you can stack them.
Make sure the 2nd switch is powered off and without any configuration (including "vlan.dat") before attaching the stacking cable.
Only when you have attached the two stacking cables do you apply power to the 2nd switch.
01-06-2013 01:36 AM
Thanks Leolaohoo..
Two more thing i would like to know
1) As per you we can similar in vice versa case if we want to create 24 port switch as Master and 12 Port as Slave one.
2) Is it possible to create stacking in between both switch (3750 X) but both switch having different version of Universal image ??One having higher version of universal image and other lower version of image.
I will be thanks for you if you response on this...
Ganesh Gupta
01-06-2013 02:05 AM
ALL switch members of a single stack must have the same IOS and the same Feature Set.
Yes. You can make your 24-port as Master and the 12-port as slave. Or whichever you want. The most important thing to remember is this:
1. Make sure the slave switch does NOT have any config (including "vlan.dat" file);
2. Power down the slave;
3. Attach stacking cable;
4. Power on the slave; and
5. Configure switch priority to the master (set to "15") and the slave (any number between 2 to 14).
01-06-2013 05:47 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
leolaohoo wrote:
2) Is it possible to create stacking in between both switch (3750 X) but both switch having different version of Universal image ??One having higher version of universal image and other lower version of image.ALL switch members of a single stack must have the same IOS and the same Feature Set.
My understanding, feature sets (or feature licenses) (excluding LANBASE feature set) don't have to match. Most common reason for this is to avoid the need to purchase full L3 for all stack members. When done, if you want L3 stack redundancy, you'll want at least two stack members with the L3 feature set (or license). (NB: I know for a fact it worked on the original 3750 series with different IOS feature set images. I'm told, by my Cisco SE, it will work on 3750X series with different feature licenses.)
My understanding is sometimes the actual installed versions don't have to match, but this should really, really be avoided! (My undestanding that this sometimes works due to auto-upgrade feature as stack can use, in some case, master's image. However it get "messy" as there are many requirements, including, I recall [?], stack ring support, per individual IOS version, for it to work correctly. Again, it's best avoided. I.e. even if "all must" isn't always technically accurate, assume that it is.)
