Router on a Stick Help
kristkrist12
Hello, my name is Chris and  I am new to the discussion forums.  I am having trouble pinging pc-pc with my PKT Tracer configuration.  I have searched the forums and instructional vids but just can't seem to get the pc's to communicate.  Can anyone look at this for me?
shamax_1983
Level 3
Level 3
Hello Christopher,
Welcome to the forum..
Had a look in to your PKT setup,
You just need to "no shut" the physical interface on the router
Router(config)#interface FastEthernet0/1
Router(config-if)#no shutdown
That's it.. everything else is perfect !!
The  thing that gets you here is that, even if you "no shut" all the sub-interfaces they wouldn't have any effect if the physical interface is still shut down..
PS: once you have enabled the physical interface, your sub-interface level "shut/no shut"s will come in to effect
Please rate this post if helpful
Shamal
Reza Sharifi
I can't open the attached file. Can you repost it using a different application?
shamax_1983
Level 3
Level 3
Hello Christopher,
Shamal
Perfect!  Thanks a lot!
