Stacking Catalyst 9300
mikeok
Frequent Visitor
Frequent Visitor
Hello!
I have a stack of 3 Catalyst 9300 switches and have to connect 2 other to the stack.
Output "sh version" from the stack shows
Cisco IOS XE Software, Version 16.12.02
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc1)
And both new switches have version
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc2)
Will this difference in releases [fc1 vs fc2] prevent to stack the new switches or not? Should they be the same of it is enough to have the same major version 16.12.02?
Thanks!
Mark Elsen
 - Probably not an issue when adding to a stack , in  the below thread the answer of andrew b explains the difference between fc1 and fc2.
              https://community.cisco.com/t5/server-networking/ios-features/td-p/978986
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
