C3850 Problems with Rapidly Increasing "Out Of Discard"
JUNHOLEE95720
hi
This is our problem.
White paper - "C3850-12S" - "2960X"
However, the 2960X is in a situation where it is hanging and we found a large number of "out of discards" per port in the C3850
1. How can I do this?
2. Is this the easiest way or is there a command?
3. Are there any caveats when "2" applying?
I attached the log, so I can refer to it.
post the output of:
show platform port-asic stat drop GigabitEthernet1/0/1
You could have oversubscribed interfaces, so some sort of buffer tuning might help...
balaji.bandi
you need to check what kind of version running both the side to look for bugs.
i see some 3850 having bugs similar kind of issue
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb65304/?reffering_site=dumpcr
BB
post the output of:
What commands are available for buffer tuning?
Leo Laohoo
Try this:
qos queue-softmax-multiplier 1200
