Stacking cisco 3750G with 3750
renjith.john
Could any tell me whether it is  possible to stack WS-C3750-48TS-S with WS-C3750G-24TS-S?
6 Replies 6
Jon Marshall
Yes it is.
Jon
manju.cisco
Level 3
Level 3
Hi Renjith,
As Jon said, yes. But pls make sure you use the same IOS verison's & same revisions for both switches.
Hi Ranjith,
As stated, Yes you can do that...
And in general this is what you need to do....
  1. Unstack both switches and reboot them.
  2. Make sure both switches are booting the SAME IOS binary file. If they are different versions it won't work.
  3. Save a copy of the both switches configurations on your PC (if you need to keep the configuration)
  4. Do a write erase on both switches.
  5. Power them both off.
  6. Stack them
  7. Power them both on (if you have a preference for which one you want as Master, power that one on first wait a few minutes and then power on the other one.)
Please rate the helpfull posts.
Naidu.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not  be construed as rendering professional advice of any kind.   Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As the others have already noted, yes you can.  I believe any 3750 can be stacked with any other 3750, although other considerations/issues might arise.  For example, the C3750G-12S supports a unique, to it, SDM template; mixed 3750 series (i.e. original, -E, -X) are more difficult to upgrade; -X series units can share power; mixing original 3750s with -E/-X 3750 loses Stackwise+ features; etc.
Thanks for your reply .
Please let me know that whether there is any document saying that any 3750 can be stacked with any other 3750.
Please find the below discussion for the same.
http://blog.qsolved.com/2011/05/is-it-possible-to-stack-3750g-and-3750x.html
http://www.learnios.com/viewtopic.php?f=16&t=12983
Naidu.
