stackwise 160
serge123
Level 3
Level 3
can you stack WS-C3650-24TS with WS-C3650-24TS-E?
Thank you
5 Replies 5
Philip D'Ath
Meraki Community All-Star
Physically yes - but you really need the same licence on both switches, which means you would need to upgrade the licence on the WS-C3650-24TS to enterprise as well.
Otherwise if you have a failure and switch over to the non-enterprise licence switch all those advanced features you were using will suddenly disappear and probably leave you with a non-working environment.
So physically yes, practically no.
All my 3650 are using IPServices for licencing. I notice ios xe 3.7.x displays WS-C3650-24TS-E but switches with ios xe 3.6 and lower are displaying WS-C3650-24TS.
I will enable " software auto-upgrade enable " prior to adding the stack kit
Philip D'Ath
When it says -E, that means you bought it with IP Services.  Otherwise you have to add IP Services separately as a licence, but that doesn't change the part number.
As long as I have same software on switch in same stack I should be good
thank you
Here all switch have same licence but IOS XE lower then 3.7 does not display the -E
SWITCH A#sh license right-to-use
 Slot#  License name   Type     Count   Period left
 1      ipservices   permanent     N/A   Lifetime
License Level on Reboot: ipservices
SWITCH A#sh mod 1
Switch  Ports    Model                Serial No.   MAC address     Hw Ver.       Sw Ver.
 1       28     WS-C3650-24TS         <SNIP>        <SNIP>          <SNIP>       03.03.05SE
switch B#sh license right-to-use  slot 1
switch B#sh mod 1
 1       52     WS-C3650-48TS         <SNIP>        <SNIP>         <SNIP>           03.06.04.E
SWITCH C#sh license right-to-use slot 1
SWITCH C#sh mod 1
 1       28     WS-C3650-24TS-E       <SNIP>       <SNIP>          <SNIP>        03.07.02E
Philip D'Ath
Yes it does.  Here is an example of a switch running 3.6.5 showing that is is reporting it is the -E model.
#show module 1
1 32 WS-C3850-24T-E FCW20xxxxxx 2c0b.e908.xxxx V07 03.06.05E
