Stackwise 3750
a.perriman
Community Member
We have a cisco stack with 5 ws-c3750-24p 12.2)55)SE3 c3750-ipbasek9-m switches. Can i add a switch to the stack that is the following model:
ws-c3750g-48ts 12.2(25)see3 c3750-ipbase-m
Kyle McKay
Level 7
Level 7
Yes you can. However - keep in mind that the IOS and feature-set will need to be upgraded to the same or a closer level on the 3750g-48ts in order for it to be successfully stacked with the 3750-24ps.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Unsure in your case.  All 3750s support the stack physically, but there can be issues when IOS software is different (whether the different IOSs support the same major/minor stack version).
Generally, you always want to insure all stack members are running the same IOS version.
Ideally, they should also have the same feature set, but this isn't required.  If all stack members don't have the same feature set, if the stack master fails you may lose IOS features.  E.g. stack master has Service image and full OSPF routing is being used, all other stack members have Base image, stack master fails you lose OSPF routing.  (For last, if just one other stack member also had Service image, by default, it should win stack election and OSPF routing would be maintained.)
Great thanks for the replys. I will upgrade the IOS to the same level and test.
