Stackwise 3850 for VSS dual active detection
Hello
by means of 3750 or 2960-S stacks, it was impossibile to perform VSS dual active detction
using ePAgP trough a MEC towards different members of a stack.
Here the QA docs for 3850 state it is now supported:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
Though, I'd like to read some confirmation from someone already using it in production or maybe
from some up to date Cisco representative.
I'd like to use lots of 3850 stacks as access switches linked to a 6500 VSS pair. In order to keep
everything redundant i would like to couple VSLP Fast Hellos and ePAgP trough the Stackwise 3850s
but not before making myself sure it's actually supported.
francesco
Francesco,
I have deployed stacks of up to five 3850 switches with stackwise and powerstack cables, there are no issues running active/active on redundant links.  I recommend using LACP.
5 Replies 5
Reza Sharifi
Yes, you can.  I just recently used a 3850 for dual active detection for a set 4500 switches (VSS).
A standalone 3850 or a stack? My doubt is using DAD crossing multichassis etherchannel
through different switches within the same stack.
thx
Francesco,
I can confirm i performed the same config.
Thank you
fp
jayesh.acharya1
Community Member
Hello Francesco,
Could you suggest me to configure failover in two cisco 3850 switch connected with stack cable
