Switching
muraripadhan
Level 3
Level 3
My requirement is
Vlan 10,Vlan 20, Vlan 30 should communicate with 172.141.0.2
I have two core switch
Core 1 (which is connected with Router) ip address is 172.141.0.2/16(Vlan1)
Core 2(Where vlan10, vlan 20,vlan 30) configure
And other switch are IP are in vlan 1
So i need to communicate all vlan (vlan 10, Vlan20, Vlan30) with 172.141.0.2
acampbell
With static routing you could try
R1
ip routing
ip route 172.16.8.0 255.255.255.128 172.141.0.140 name TO_VLAN10
ip route 172.16.2.0 255.255.255.128 172.141.0.140 name TO_VLAN20
ip route 192.168.1.0 255.255.255.0 172.141.0.140 name TO_VLAN30
R2
ip routing
ip route 0.0.0.0 0.0.0.0 172.141.0.2 name DEF_ROUTE_TO_R1
Hope this points you in the right direction.
Alex
Regards, Alex. Please rate useful posts.
acampbell
R1
ip routing
R2
ip routing
Alex
Its correct answer because i have already implement my network and its working fine now
Thanks  hacampbell
Deepak Kumar
 Please follow the following steps:
Option 1.
1. Make a trunk port between R0 to MS0 and allowed all VLANS on this trunk port.
2. Configure Gateway IPs in each VLAN on router R0.
3. Configure Static route on the router.
Option 2. ((Recommended for Live Network))
1. Make an access port between R0 to MS0 with different VLAN ID and Subnet.
2. Configure Gateway IPs in each VLAN on the core switch.
3. Configure IP Routing on the core switch.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
