06-15-2022 11:46 PM
it's possible to stack 2 9200 switches, same model but one is advantage, the other one, essentials?
Solved! Go to Solution.
06-16-2022 12:17 AM - edited 06-16-2022 12:21 AM
OLD Models like cisco 3750 (if i recall 3850 we used to do that different Licenses)
Unfortunately I do not believe that supported in new Cat 9K models ( as I am aware and tested)
All the switches in the stack must be running the same license level as the active switch. For information about license levels, see the System Management section of this guide.
All the switches in the switch stack must be running compatible software versions.
06-16-2022 01:39 AM
Thank you
