Showing results forĀ
Search instead forĀ
Did you mean:Ā
Rate Limit on Port Channel in Nexus 5 k
Anmol30
How can we apply rate limi policy on Nexus 5k interface or portchannel??
Thanks in advance
6 Replies 6
balaji.bandi
Some Limitation as per my experience you can only to inbound. May be newer version may be changed ( as of 7.X)
May be worth Looking QoS  config :
https://netcraftsmen.com/configuring-qos-on-the-nexus-50002000-part-2/
BB
Thanks for your revert.
I have the latest upgraded iOS in switch 7.3.8 but still it's not working
for output
So you have nexus os 7.3.8 running, how does your configuration look like? what is not working?
BB
Hi Balaji,
I am unable to apply rate limit policy for outbound.
What does your configuration look like?
Note: as I have mentioned there is some Limitation.
BB
I honestly don't see rate limiting (at least the 'traditional'' rate-limit command related) as an option at all on the N5K.
bandwidth percent
is supported and can be applied to an outbound service policy...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/qos/b_Cisco_Nexus_5000_Series_NX-OS_Quality_of_Service_Configuration_Guide/Cisco_Nexus_5000_Series_NX-OS_Quality_of_Service_Configuration_Guide_chapter3.html#task_409C4652948E42B5...
