stackwise  and solution
dhikra-marghli8
Hello
first question :
if the port-channel fails , then i want to know which we will use as a solution ( architecture , or  design LAN )  to avoid port-channel fails ?
second question
in the technology stackwise  ( old ) , etherchannel is configured in port uplink or port downlink ?
third question ;
if either switch failed in tecnhlogie stakewise ( old )  , all network failed ==
> then what's the solution  replaces  ( old stakiwse )  and will be optimised
i wait a reply from expert network
M02@rt37
Hello @dhikra-marghli8
First question :
To avoid port-channel failures, implementing redundancy and resilience in your network architecture is the way. This may involve using technologies like STP for loop prevention, implementing redundant links, and designing a robust network topology.
Second question :
EtherChannel can be configured in both uplink and downlink scenarios. In an uplink scenario, EtherChannel is typically used to bundle multiple physical links between switches or between a switch and a router. In a downlink scenario, it might involve aggregating links connecting to end devices like servers or workstations, endpoints!
Third question :
If a switch failure in stackwise causes a network-wide failure, you should consider to transitioning to newer technologies like Virtual Switching System called 'VSS' or stacking with enhanced features. These technologies provide improved scalability and resiliency, ensuring that a failure in one switch doesn't result in a complete network outage. Additionally, optimizing the network design and incorporating features like ECMP can enhance overall network performance and reliability.
Best regards
8 Replies 8
Leo Laohoo
Do not put the physical ports all in one switch member.
this is an answer to what question ?
Joseph W. Doherty
#1 Fails how?
#2 Both.
#3 With StackWise, single member switch failure should NOT result in ALL network failure.
nor clear you answer
i want answer clear for three question
Well, I answered questions 2 and 3.
As to question 1, it was unclear.  Basically, I was asking what you considered a port-channel failure, as port-channel is used to avoid a single point of failure, especially on a multiple member switch stack.
amitpalsingh
first question :
Answer: If you have a stack of 4 switches , have one port from each switch as part of port-channel... if any of the switch fails your port-channel will remain up
second question
It depends on your requirement , you can configure it both ways
third question ;
if primary and standby both switches fail then you have a problem, but if only one fail stack should be still up and running only down stack member users will be impacted
M02@rt37
First question :
Second question :
Third question :
Best regards
Bravo , this is the answer that i want
it is very  very clear
