Cisco switch is stuck at booting loop with unknown symbols and lines
jose diaz
 I have this problem, cisco switch catalyst 3850 keeps at boot looping, how can I recover?
balaji.bandi
Make sure you use the right baud rate to get working.
check boot recovery :
https://community.cisco.com/t5/networking-knowledge-base/recovering-from-a-3850-boot-failure/ta-p/3136638
BB
Hi there, I´m trying to run emergency-install from USBFLASH0: from rommon mode, but it shows up this error
any solutions?
take lower USB stick like 8GB and not (USB 3.0 - some may have issue) - make sure it format  FAT.
If you like you can also try TFTP methods, best is USB
BB
Find a Toshiba- or PNY-branded USB flash (<64 Gb).
Format to FAT16.
