StackWise cables over 3 Meters?
ROCKY CHEUNG
Community Member
I am trying to stack up few Catalyst 3750E switches which they will be mounted in different racks. One of these stackwise cable was being just little short even using 3 meter one (CAB-STACK-3M=), I'm wondering if there is anything longer than 3 meter stackwise cable is available by Cisco or 3rd party? or even custom made one?
Thanks in advance!
There are no standard stack cables larger then 3 Meters...
You can create 1 yourself ... or ask a company like http://www.ciscoanywhere.com to make a custom one for you.
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
unfortunately ciscoanywhere.com does not make custom cable.
Do you know any other vendor makes custom cables?
Thanks!
