StackWise calbe longer than 3 Meter
Patrick Werner
Hi Community.
Have someone of you guys used StackWise cable to stack 3750 together that are longer then 3 meter.
I've seen online sales with 5 meter, 7.5 meter and 10 meter cables.
Best Regards Patrick
Rajeev Sharma
Hey Patrick,
Maximum stackwise cable length is 3m as per cisco documentation.
HTH.
RS.
Hi.
Yes i know what is written in the docu. But has anyone used longer then 3 meter for stacking together two 3750 switches. Longer cables are available but not from Cisco.
Not an option with an official Cisco part number. You can find some aftermarket stack cables that are longer (I have seen up to 10m). However, keep in mind that they are not going to be supported by Cisco nor guaranteed that they will actually work :)
Thank you for rating helpful posts!
