StackWise Virtual between C9500-48Y4C and C9500 -24Y4C
RobertZak
Hello Colleagues,
Could share your experience and provide answer for a question:
Can we combine switches C9500-48Y4C and C9500-24Y4C in order to create StackWise Virtual connection?
IOS version - Cisco IOS XE Bengaluru 17.6.4.
Based on the following document:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-6/configuration_guide/ha/b_176_ha_9500_cg/configuring_cisco_stackwise_virtual.html
Both switches in the Cisco StackWise Virtual pair must be of the same switch model.
Prerequisites for Cisco StackWise Virtual
- Both switches in the Cisco StackWise Virtual pair must be directly connected to each other.
- Both switches in the Cisco StackWise Virtual pair must be of the same switch model.
- Both switches in the Cisco StackWise Virtual pair must be running the same license level.
- Both switches in the Cisco StackWise Virtual pair must be running the same software version.
- Both switches in the Cisco StackWise Virtual pair must be running the same SDM template.
- All the ports used for configuring a StackWise Virtual Link (SVL) must share the same speed. For example, you cannot configure a 10G or a 40G port to form an SVL, simultaneously.
Thanks for your answers.
marce1000
 - Ref  : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.html
                                                  It will work , check Table 2.
 M.
Thank you for you answer, but it's not correct.
I connected  switches C9500-48Y4C and C9500-24Y4C and I received warning pasted below:
Apr 14 15:59:32.349: %ISSU-3-INCOMPATIBLE_PEER_UID: Setting image (CAT9K_IOSXE), version (17.6.4) on peer uid (2) as incompatible
*Apr 14 15:59:32.349: Config Sync: Bulk-sync failure due to Servicing Incompatibility. Please check full list of mismatched commands via:
  show redundancy config-sync failures mcl
The stackwise virtual was formed, the role was assigned (active, standby)
I decided to send warning to TAC
The answer from TAC:
The StackWise Virtual configuration between different switch models is not supported.
Best regards
Robert
Hi Robert
Did you receive a solution from Tac engineer as I’m going to implement the Same
You cannot configure StackWise Virtual between 2 different switch models. The hardware needs to be exactly the same.
