06-01-2022 08:48 AM
I can't seem to get any of the stackwise virtual commands to come up. I have went through the required criteria Cisco states and I believe it is all good.
Both switches in the Cisco StackWise Virtual pair must be directly connected to each other.
Both switches in the Cisco StackWise Virtual pair must be of the same switch model.
Both switches in the Cisco StackWise Virtual pair must be running the same license level.
Both switches in the Cisco StackWise Virtual pair must be running the same software version.
Both switches in the Cisco StackWise Virtual pair must be running the same SDM template.
All the ports used for configuring a StackWise Virtual Link (SVL) must share the same speed. For example, you cannot configure a 10G or a 40G port to form an SVL, simultaneously
Can anyone think of what I am missing?
Switch 1
Cisco IOS XE Software, Version 17.03.05
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.5, RELEASE SOFTWARE (fc2)
Purchased Licenses:
C9500 Network Essentials (C9500 Network Essentials):
Description: C9500 Network Essentials
Total reserved count: 1
Term information:
Active: PID:C9500-24Y4C,SN:FDO2615190S
License type: PERPETUAL
Term Count: 1
C9500 24Y4C DNA Essentials (C9500 24Y4C DNA Essentials):
Description: C9500 24Y4C DNA Essentials
Term information:
License type: TERM
Start Date: 2022-JUN-23 UTC
End Date: 2025-JUN-23 UTC
Term Count: 1
Twe1/0/23 connected 1 full 10G SFP-10GBase-LR
Twe1/0/24 connected 1 full 10G SFP-10GBase-LR
Switch 2
Purchased Licenses:
Term information:
Active: PID:C9500-24Y4C,SN:FDO261529ZL
Term Count: 1
Term information:
License type: TERM
Term Count: 1
06-01-2022 09:30 AM
06-01-2022 09:41 AM
you can use network advantage License boot level and test it :
config t
(config)#license boot level network-advantage
wr
reload
=====️ Preenayamo Vasudevam ️=====
