Stackwise-Virtual on 3850-XE-E
Xavillon
Visitor
My post concerns the new technology Stackwise-Virtual on 3850-XS-E.
I didn't find a lot of informations appart these informations:
- It's only compatible with version Denali 16.3.3.
- It works only on 2x 3850 and no more.
- We have to configure SVL link and optionnaly DAD.
- Only port 45-48 are compatible for SVL link
My questions concerns 2 parts:
1) The optimisation of my configuration.
2) The management of the active standby.
1)
Concerning my configuration, i do the following:
On switch 1 and 2:
stackwise-virtual
domain 100
interface range te1/0/47 - 48
stackwise-virtual link 1
interface te1/0/46
stackwise-virtual dual-active-detection
Question:
- Is it the optimal configuration (I try through port-channel but it didn't work)?
- Concerning stackwise-virtual link can we use other than id 1?
2)
I also try to search information concerning the management of standby and master state but without success.
By searching through command line I see:
show switch
Switch/Stack Mac Address : 70f3.5a0f.0600 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 70f3.5a0f.0600 1 V02 Ready
2 Standby 70f3.5a11.6500 1 V02 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 OK DOWN 2 None
2 OK DOWN 1 None
It's seems to use the stack logic concerning role management.
Question:
- If my understanding is right virtual stacking is hybrid between VSS and stack:
I configure the "virtual-stacking" as a VSS through VSL link and DAD.
I configure switch ID and priority as a normal stack.
Is it correct?
3)
If it is correct  for example, if I want switch 1 be the master for control plane I have to do the following:
On switch 1
switch 1 priority 15
stackwise-virtual
domain 100
interface te1/0/46
On switch 2
switch 1 renumber 2
switch 2 priority 14
stackwise-virtual
domain 100
interface te1/0/46
Thank you for your help.
Best regards,
MC.
Leo Laohoo
It only works on the 48-port SFP/SFP+ model of the 3850 and the new 9500.  Not all models are supported on the 3850.
I used 3850-48XS-E.
What about others points?
Thank you
freost
Visitor
From this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/configuration_guide/b_163_consolidated_3850_cg/b_163_consolidated_3850_cg_chapter_010101001.pdf
You can configure any physical port as a StackWise Virtual link.
why are you saying only ports 45-48 worked for SVL?
