StackWise Virtual Pair Connection to ASA
zekebashi
Level 8
Level 8
Hell,
Ref. diagram attached.
Focusing on the ASA uplinks and downlinks to a pair of C9500 switches which are configured in a StackWise Virtual mode. The two physical ports on the ASA will be bundled into a L3 Port-Channel. From the ASA, each physical port will be connected to switch A and the other physical port will be connected to switch B in the stackwise domain. I was wondering if this design would work from the ASA stand-point. Meaning, can an ASA configured in a port-channel have one port connected to a switch and the other port connected to another switch considering that the switches are configured in a visualized mode (SV or VSS)?
Francesco Molino
If the 2 links of a PO goes into 2 switches built as StackWise Virtual or VSS, it will work without issue and it’s a supported design.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
