Static and dynamic mac addresses
Andy White
Level 3
Level 3
I just need a refresher here, I have  a few PC plugged in to a switch and when I do  show mac-address-table some ports are dynamic and some are static, why are some static?
I have this configured on all ports:
switchport mode access
switchport port-security
switchport port-security aging time 1
switchport port-security aging type inactivity
spanning-tree portfast
spanning-tree bpduguard enable
What makes one port dynamic and one static as the ports are configured the same?
rfalconer.sffcu
Level 3
Level 3
What is the MAC entry on the static? Sometimes the statics are HSRP MAC addresses and others are used for IPv6 multicast.
You can check HSRP with sh standby vlan x and look at the MAC address to see if it matches the static entry.
The IPv6 multicast start with 3333.
