Static/Default Routes
Woodland73
Community Member
Hi Everyone,
This is a very easy inquiry, and I'd appreciate your answers.  I'm still preparing for ICND1, and I have three routers set up, in Packet Tracer.  The setup is in the attached pic.
R2 has a loopback address of 2.2.2.2, and, for the purposes of R3 being able to ping it using R1 as an intermediary, I've added the following, to R3:
R3#show ip route
Gateway of last resort is not set
2.0.0.0/24 is subnetted, 1 subnets
S 2.2.2.0 [1/0] via 10.1.2.1
3.0.0.0/24 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.2.0 is directly connected, FastEthernet0/1
Here's what I've added, to R1:
R1#show ip route
Gateway of last resort is 10.1.1.2 to network 0.0.0.0
* 0.0.0.0/32 is subnetted, 1 subnets
S* 0.0.0.0 [1/0] via 10.1.1.2
10.0.0.0/24 is subnetted, 2 subnets
C 10.1.1.0 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.1.1.2
As a reference, here's what's on R2:
R2#show ip route
C 2.2.2.0 is directly connected, Loopback0
My purpose is simply to get R3 to ping/communicate with R2 through R1, using static routes.  I get five periods when trying to ping R2, from R3 (not even U's appear).  What am I doing wrong, here?  Any help is much appreciated.
6 Replies 6
saif musa
Level 9
Level 9
Woodland,
What is the problem, Please clarify ..
You're right; I didn't completely clarify my purpose.
I'm wanting R2 and R3 to communicate with each other, using R1 as the forwarding router.
If You do a standard ping from R3 towards R2 ip 2.2.2.2 the router R3 uses ip 10.1.2.2 as a source for the packet.
R3 looks in his routing tabel a see 2.2.2.0 in the routing table and forwards the packket towards R1.
R1 get the packet looks in hos routing table, see 0.0.0.0  and forwards the packet to R2.
R2 gets the packet realize it is for himself, processes the packet, construct a return packet towards R2.
R2 looks in the routing table to look for 10.1.2.2, doesn't have an entry for that detination and therefore drops the packet.
/Mikael
Ok, now its clear that you miss configured ( ip default-network ) command. Do it as follows;
R2
ip default-network 10.1.1.0
R3
ip default-network 10.1.2.0
Please rate if its helpfull
grapevine
Level 5
Level 5
Please paste the below output from all the three routers:
sh run | i ip route
sh ip int brief
Woodland73
Community Member
