Static IP routing Between 2 WAN
muthukumar
Community Member
Actually I am beginer with router. I have cisco 2811 router. I have two FE interface and two Serial interface in my router.
I want route FE1 to S0(WAN1) and FE0 to S1(wan2) respectively. Is it possible? please help me out.
2 Accepted Solutions
kamal-learn
Level 7
Level 7
yes you can do just mark all the traffic comming from Fe1 and Fe0 separately and send it to a specific interface or a destination using route-map command
route-map ....
match access-group acl-101
set ....
do rate if it clarify
kamal-learn
Level 7
Level 7
route-map ....
set ....
you can configure route maps for this.
check out this URL:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca590.html#4553
rate if it helps ....
Yes. Its done. Thank You Very Much
