Static NAT based on destination subnet
dennylester
I need a Cisco 1841 router to perform Static NAT only for a given remote destination.
For example, we have
Site A
192.168.1.0/24
Site B
192.168.2.0/24
Site C
10.9.0.0/16
Site A <==> Site B <==> Site C
When Site A talks to Site B I don't need a NAT translation. But when Site A talks to Site C, I need the router at Site B to NAT 192.168.1.0/24 to 10.40.1.0/24. When Site C talks to 10.40.1.0/24 I need it to NAT to 192.168.1.0/24.
I've been able to get it to work using route-maps and dynamic NAT pools, but it's not the way I need it. For example, 192.168.1.158 is being NATTED to 10.40.1.1 instead of 10.40.1.158 and the return traffic isn't making it back.
I sure hope this makes sense.
Denny
Marwan ALshawi
try this on router B:
access-list 100 permit 192.168.1.0 0.0.0.255 10.40.1.0 0.0.0.255
route-map nat1 permit 10
match ip address 100
ip nat inside source static 192.168.1.0 10.40.1.0 route-map nat1
and apply ip nat inside on the interface facing site A and ip nat outside on the interface faceing site C
and have a look at the following link as well:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t4/feature/guide/ftnatrt.html
good luck
if helpful Rate
This kind of worked. The IP Nat inside source static only did a one to one translation.
I need
ip nat inside source static network 192.168.1.0 10.40.1.0 /24
but it won't let me reference a route-map. I suppose I can manually create 254 one to one translations.
Denny
jpoplawski
Can I ask why the need for NAT? It seems like you should just be able to turn on ospf or eigrp and route the traffic accordingly? I don't want to oversimplify, however doing a one to one nat for 254 hosts, sounds pretty cumbersome.
Overlapping subnets.
Site C bought us out and assigned us a block of private addresses. We haven't renumbered Site A yet but need the connectivity right away. Somewhere on the Site C network they have an overlap and mandated we change our end.
Since Site B was ours to begin with, all their hosts are currently configured to access Site A resources on the old subnet.
The good news is the one to one configuration went pretty quick using Excel and notepad and pasting the configuration into the router.
