Static NAT on an ASA 5505
crewdog10
Hello I'm new to the forum. Hope this works out. Basically I have a test lab consisting of two ASA's both running IOS 8.4. I would like to connect the outside interface of ASA2 to the DMZ on ASA1 and use the outside interface on ASA1 for ISP connectivity. On the ASA 2 I cannot get my internal hosts to ping either ASA1's DMZ interface or ASA2's Outside Interface. They can ping ASA2's internal IP. From each ASA I can also ping the 5.1 and 5.2 IP addresses. I have configured NAT according to the 8.4 IOS CLI guide but it does not appear to be working. I have also attached my config from ASA2. What am I missing to nat from the inside to outside interfaces?
ASA1 (Internet Connected)
DMZ: 192.168.5.1 /24
Outside: DHCP from ISP
ASA2 (Internal Test Lab)
Outside: 192.168.5.2 /24
Internal: 172.16.0.1 /16
ASA Version 8.4(2)5
hostname ASA2
enable password **************** encrypted
passwd **************** encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.16.0.1 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.5.2 255.255.255.0
boot system disk0:/asa842-5-k8.bin.exe
ftp mode passive
object network NatInternal
subnet 172.16.0.0 255.255.0.0
object network NatInternal_mapped
subnet 192.168.5.0 255.255.255.0
object network Internal_Range
range 172.16.0.11 172.16.0.17
object network External_Range
range 192.168.5.11 192.168.5.17
object network natinternal
object-group network obj_any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NatInternal NatInternal_mapped destination st
atic Internal_Range External_Range
route outside 0.0.0.0 0.0.0.0 192.168.5.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 172.16.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DD
CEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:c2bda9f1ae788fef7d24aa19b7bf9c83
: end
6 Replies 6
crewdog10
Wow not a single reply for an easy question. Did I post this in the wrong area?
on ASA2 try this:
inspect icmp
Regards.
Alain.
That didn't work. I don't think it's an issue with ping but with how I set up nat.
Ed
1) you will need Alain's config because you need to tell ASA1 to allow ICMP back in
2) you won't be able to ping ASA1's outside interface from behind ASA2. It is a security feature that you cannot ping through an ASA to an interface. You should try pinging beyond ASA1 ie. the internet but you will need to add Alain's config to ASA1 as well.
3) You should be able to ping ASA1 dmz IP. Your NAT setup is a bit cut off in what you posted. Can you describe exactly what it is meant to be doing ?  Also do you need to NAT one set of IPs to another or would it be okay if you natted all internal 172.16.x.x. addresses to the 192.168.5.2 address assigned to the outside IP of ASA2 ?
4) There is a firewalling forum but you may as well keep it here now
5) How do you know it is such an easy question
Jon
First off, thank you both Alain and John. I am now able to ping from my VM'S on ASA2 to the DMZ interface of ASA1. Great! My intention was to have the IP's statically mapped to make troubleshooting easier. Ideally I'd like to have:
VM on ASA2           NAT'd to
172.16.0.11             192.168.5.11
172.16.0.12             192.168.5.12
172.16.0.13             192.168.5.13
Etc.... And from the DMZ of ASA1 use PAT to the outside interface for the ISP connection.
Now although my VM's can now ping ASA1 (192.168.5.1), on the ASDM for ASA1 it shows that the source IP address is 192.168.5.2 and not what I would like to be 192.168.5.11 for VM1.
The last challenge I have is getting the VM's on the internet. I thought that on ASA1 I could just copy the rule "nat (inside,outside) after-auto source dynamic any interface" and paste it to "nat (dmz,outside) after-auto source dynamic any interface dns" but that did not work. I also noticed that inbound DNS queries from ASA2 to ASA1 are being denied.
Ideally I'd like the VM's statically NAT'ed and be able to get them on the internet.
Any help is appreciated.
I got on the ISP by changing the DMZ security level to 50. Now all I have to work on is the static NAT which I can do a bit later. Thank you Sir's ;-)
