Static Route Load Balancing?
Anthony Holloway
I have no way of testing this, but I am wondering if I could have two ISP connections that use static routes (ie 0.0.0.0 0.0.0.0 a.b.c.d) and load balance between the two conections to the internet? AFAIK loab balancing is a benifit of routing protocols only.
3 Accepted Solutions
ankbhasi
Hi Friend,
If you have 2 ISP connection and you have 2 default route with same admin distance it will have load balancing.
Tye type of load-balancing you get (i.e. per packet or per destination) depends on the switching mechanism deployed on the router.
Ankur
Hi Friend,
If router is configured for fast switching which is default it will do load balancing per destination and if you conigire your router for process switching the load balancing will be per packet.
Ankur
* plz rate the post if it helps
If the connections go to 2 different ISP the outgoing traffic will be load balanced while the incoming traffic may not be loadbalanced which largely depends on how the internet views your subnet.
Check the link for information on router switching mechanism
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_white_paper09186a00800a62d9.shtml
Narayan
ankbhasi
Hi Friend,
Ankur
Thank you for the quick reply.
What do you mean by switching mechanism?
Hi Friend,
Ankur
Narayan
