Static Route with excluded subnets
jennyjohn
How can I create a static route that points
10.0.0.0/8 to go via the gateway 192.168.1.1, but excludes the subnets 10.100.0.0/16 & 10.101.0.0/16 from this static route.
Thanks in advance.
5 Replies 5
Vaibhava Varma
Level 4
Level 4
Hi jennyjohn
If we have an alternate routing gateway for 10.100.0.0/16 and 10.101.0.0/16 we can create specific routes for above subnets pointing to different Next-Hops and the Routing Table will always prefer the most specfic route for above subnets under normal condtions as long as the alternate GW is available.
Varma
johnlloyd_13
Level 9
Level 9
hi,
you can achive this using an ACL.
interface Vlan10
ip address 192.168.100.1 255.255.255.0
interface Vlan20
ip address 10.100.0.1 255.255.0.0
interface Vlan30
ip address 10.101.0.1 255.255.0.0
ROUTER1(config)#ip route 10.0.0.0 255.0.0.0 192.168.1.1
ROUTER1(config)#access-list 100 deny ip 10.100.0.0 0.0.255.255 any
ROUTER1(config)#access-list 100 deny ip 10.101.0.0 0.0.255.255 any
ROUTER1(config)#access-list 100 permit ip any any
ROUTER1(config)#int f0/1
ROUTER1(config-if)#no switchport
ROUTER1(config-if)#ip address 192.168.1.2
ROUTER1(config-if)#ip access-group 100 out
ROUTER2#sh ip int bri
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        192.168.1.1     YES manual up                    up
FastEthernet0/1        unassigned      YES unset  administratively down down
Loopback1              10.0.0.1        YES manual up                    up
Vlan1                  unassigned      YES unset  administratively down down
PC>ipconfig
IP Address......................: 192.168.100.50
Subnet Mask.....................: 255.255.255.0
Default Gateway.................: 192.168.100.1
PC1>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=63ms TTL=254
Reply from 10.0.0.1: bytes=32 time=32ms TTL=254
Reply from 10.0.0.1: bytes=32 time=47ms TTL=254
Reply from 10.0.0.1: bytes=32 time=31ms TTL=254
Ping statistics for 10.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 31ms, Maximum = 63ms, Average = 43ms
PC2>ipconfig
IP Address......................: 10.100.0.50
Subnet Mask.....................: 255.255.0.0
Default Gateway.................: 10.100.0.1
PC>ping 10.0.0.1
Reply from 10.100.0.1: Destination host unreachable.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
PC3>ipconfig
IP Address......................: 10.101.0.50
Default Gateway.................: 10.101.0.1
PC>ping 10.0.0.1
Reply from 10.101.0.1: Destination host unreachable.
Jon Marshall
Can you be more specific ie.
do you want to route 10.100.0.0 & 10.101.0.0 to a different gateway ?
If so you may need to use PBR for this.
Jon
Thanks for the reply, Jon.
10.100.0.0/16 & 10.101.0.0/16 subnets are part of my network itself and I need to add a route on the gateway to send all other 10.0.0.0/8 networks out on to the MPLS. How can I use PBR for this?
you can do something like that
ip prefix-list SUBNET100-101 permit 10.100.0.0/16
ip prefix-list SUBNET100-101 permit 10.101.0.0/16
route-map SUBNET100-101
match ip address prefix-list SUBNET100-101
set ip next-hop x.x.x.x
ont the interface where these subnets are connected:
ip policy route-map SUBNET100-101
Regards.
Alain.
