static routing on 2960S?
nico.deranter
I'm trying to setup static routing between VLANs on a WS-C2960S-24TS-L.  I installed firmware 15.0(2)SE which is supposed to be able to do that but when I try to configure 'ip routing' the command isn't recognized.
I did the same some time ago with WS-C2960G-24TC-L and that one works fine.
Any idea what might be wrong
WS-C2960S-24TS-L
  sw version: 15.0(2)SE
  SW Image:C2960S-UNIVERSALK9-M
WS-C2960C-24TC-L
  sw versionL 15.0(1)SE3
  sw image: C2960-LANBASEK9-M
The only thing I can think of is that the Universalk9 image doesn't contain static routing, altough according to the release notes it should be able to do that. It's the only image I can download for the C2960S anyway.
Any ideas what might be wrong?
Nico
cadet alain
have you changed the sdm to sdm prefer lanbase-routing  and reloaded ? ---> sh sdm prefer
Regards.
Alain
cadet alain
Regards.
Alain
Thanks, that's what I needed!
For the records: the following will enable static routing on a C2960
# config t
(config)# sdm prefer lanbase-routing
(config)# exit
copy run t
reload
