Etherchannel load balance
Mark Woollam
                   If a core and access switch have different etherchannel load balance methods, will the mismatch cause errors or performance issues?
e.g
Core src-dst-ip
Access src-mac
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Errors no.  Performance perhaps, but not due to the "mismatch" but might be due to suboptimal hash algorithm.
BTW, in ye olden times, optimal hash selection often required different "mismatched" choices.
stephen.stack
Level 4
Level 4
Mark,
The algoritm is applied in the outbound direction only - they do NOT need to match. There is no negative impact in my experience. Only the flows may not look as symetrical as you might expect. I recently made this change on a network and have had no issues since.
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
