12-23-2017 06:37 AM - edited 03-08-2019 01:12 PM
Good morning with everyone, please consult. In all my Switch 3750 installed, some static macros have come.
CC3750G_Concent_4toPiso_103#sh parse macro brief
default global : cisco-global
default interface: cisco-desktop
default interface: cisco-phone
default interface: cisco-switch
default interface: cisco-router
default interface: cisco-wireless
CC3750G_Concent_4toPiso_103#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 17-Aug-16 13:28 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
CC3750G_Concent_4toPiso_103 uptime is 1 week, 3 days, 11 hours, 11 minutes
System restarted at 22:18:30 GMT Tue Dec 12 2017
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE11/c3750-ipservicesk9-mz.122-55.SE11.bin"
cisco WS-C3750G-12S (PowerPC405) processor (revision Z0) with 131072K bytes of memory.
Processor board ID FDO1428R1FA
Last reset from power-on
2 Virtual Ethernet interfaces
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : DC:7B:94:BE:BA:00
Motherboard assembly number : 73-9678-14
Power supply part number : 341-0048-03
Motherboard serial number : FDO1429031E
Power supply serial number : DTN142230DA
Model revision number : Z0
Motherboard revision number : A0
Model number : WS-C3750G-12S-E
System serial number : FDO1428R1FA
Top Assembly Part Number : 800-26634-12
Top Assembly Revision Number : A0
Version ID : V14
CLEI Code Number : COMA410BRA
Hardware Board Revision Number : 0x06
Switch Ports Model SW Version SW Image
* 1 12 WS-C3750G-12S 12.2(55)SE11 C3750-IPSERVICESK9-M
Configuration register is 0xF
Now, we are migrating to Catalyst 3850 models, but these do not come with static macros, like the 3750.
From where or how should I get these static macros to install them in the 3850, because, for example, in the majority of the access ports of my 200 Catalyst 3750 I use the Cisco-Phone macro, in the 3850 it does not exist.
In the TRUNK ports of my 3750, I use the Cisco-Switch macro, in the 3850 it does not exist either.
CC3850_Dispatch_New_41#
CC3850_Dispatch_New_41#sh parse macro brief
CC3850_Dispatch_New_41#sh ver
Cisco IOS XE Software, Version 16.06.02
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.6.2, RELEASE SOFTWARE (fc2)
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
CC3850_Dispatch_New_41 uptime is 5 days, 17 hours, 42 minutes
Uptime for this control processor is 5 days, 17 hours, 51 minutes
System returned to ROM by reload
System restarted at 15:50:22 GMT Sun Dec 17 2017
System image file is "flash:packages.conf"
Last reload reason: Reload Command
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Permanent ipbasek9
cisco WS-C3850-48P (MIPS) processor (revision AB0) with 853402K/6147K bytes of memory.
Processor board ID FCW2142D0J7
80 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo:.
252000K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1611414K bytes of Flash at flash-2:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 00:27:90:58:9b:00
Motherboard Assembly Number : 73-15800-08
Motherboard Serial Number : FOC21412EGY
Model Revision Number : AB0
Motherboard Revision Number : A0
Model Number : WS-C3850-48P
System Serial Number : FCW2142D0J7
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48P 16.6.2 CAT3K_CAA-UNIVERSALK9 INSTALL
2 32 WS-C3850-24P 16.6.2 CAT3K_CAA-UNIVERSALK9 INSTALL
Switch 02
Switch uptime : 5 days, 17 hours, 52 minutes
Base Ethernet MAC Address : 6c:dd:30:bd:b4:00
Motherboard Assembly Number : 73-15805-05
Motherboard Serial Number : FOC214169LY
Model Revision Number : AC0
Model Number : WS-C3850-24P
System Serial Number : FOC2142X169
Configuration register is 0x102
Please, if you can help me on this topic.
Greetings.
Regards.
Fernando.
12-23-2017 05:10 PM
