pinging outside network
onel.riveron
Visitor
Hello everyone,
I apologize if I am asking a repeat question. Please help me with this network I designed. The router with the blue X in the picture can ping the cloud. But what do I need  to be able to ping from the routers with the red X to the cloud?
Currently all routers can ping each other, but only the one with the blue X can ping the cloud.
Hello
1) do the red routers have knowledge of the cloud network
2) does the cloud network have knowledge of the red routers networks
res
paul
Kind Regards
Paul
5 Replies 5
johnd2310
Level 11
Level 11
Hi, Check your routing. Does the failing router have a route to the cloud? Thanks John
**Please rate posts you find helpful**
Hello
res
paul
Kind Regards
Paul
Are you referring to a routing protocol rip ospf etc.. ?
I'm using RIPv2, it's done on all the routers.
the interface connecting R2 with the cloud, FastEthernet3/0, has IP address 10.3.3.48. What mask does this IP address have, and how are you advertising it ? The link between R1 and R6 has 10.3.3.0/24, make sure this is not the same network as the one configured on R2. I would suggest to change the IP address of FastEthernet3/0 on R2 to something you are not using yet, e.g. 10.8.8.1/24, and the IP address of the cloud to 10.8.8.2/24.
onel.riveron
Visitor
I figured it out. Needed to setup NAT on Router R2.
I'm using RIP to advertise.
Here's my conf:
R2#sh run
Building configuration...
Current configuration : 1273 bytes
! Last configuration change at 18:23:45 UTC Sat Dec 23 2017
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
no ip icmp rate-limit unreachable
ip cef!
no ipv6 cef
multilink bundle-name authenticated!
ip tcp synwait-time 5!
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.0
ip nat inside
speed auto
duplex auto
interface FastEthernet0/1
ip address 10.2.2.2 255.255.255.0
ip nat inside
speed auto
duplex auto
interface FastEthernet1/0
ip address 10.7.7.1 255.255.255.0
ip nat inside
duplex full
interface FastEthernet3/0
ip address 10.10.1.48 255.255.255.0
ip nat outside
duplex full
router rip
version 2
network 10.0.0.0
bfd all-interfaces
no auto-summary
ip nat inside source list 100 interface FastEthernet3/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 permit ip any any!
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#
