storm control
LucaSalvatore_2
Level 3
Level 3
question about storm control and the confiuration options which are;
Switch(config-if)#storm-control broadcast level ?
<0.00 - 100.00> Enter rising threshold
bps Enter suppression level in bits per second
pps Enter suppression level in packets per second
So it can be either a percentage or in pps.
If you set it as pps, is this pps coming into the inteface?
So if you do a show interface fa0/1 command does the pps from storm control refer to the 5 minute input rate??
thanks
rajinikanth
Level 6
Level 6
pps - packets per second
Yes, Its packets coming into interface.
It Specify the rising and falling suppression levels as a rate in packets per second at which traffic is received on the port.
Raj
