Storm control
tahseen12
Level 2
Level 2
Does Cisco routers or L3 switches support
storm control on L3 interfaces???
mbroberson1
Level 7
Level 7
Hi Tahseen12,
Storm Control is a L2 technology and available only on L2 switchports. However if your needed a similar feature for L3 interfaces I would suggest you look at "boradcast suppression" which is supported on L3 intercaces.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/bcastsup.html
Please rate if this helps.
