Storm control
rajsingh68
Frequent Visitor
Frequent Visitor
Dear sir
I have two core switches (3750 in stack).
Access Switch IE-3010.
ON THE ACCESS SWITCH CCTV CAMERA ATTACHED. THE L-3 VLAN IS CONFIGURED ON CORE SWITCHES.
DEFAULT ROUTE IS CONFIGURED ON ACCESS SWITCH TOWARDS CORE SWITCHES.
I HAVE CONFIGURED THE STORM CONTROL UNICAST , MULTICAST, BROADCAST  LEVEL 65 - 87 ON TRUNK PORT IN & OUT. INTERFACE LIKE ACCESS TO CORE TRUNK LINK ONLY.
NOW ISSUE IS THAT HOW TO DECIDE THE PARAMETERS OF STORM CONTROL LEVEL.
HOW TO CHECK THE STORM CONTROL TRAFFIC ON INTERFACE FOR PARAMETERS.
I HAVE CHECK THE COMMAND :-
SHOW INTERFACE GIG X/X COUNTERS
IS THERE ANY TOOL FOR PMEASE SUGGEST.
THANKS & REGARDS
RAJ SINGH
Julio E. Moisa
There is no recommended o best practice levels, It it is evaluated by the network administrator and the services or programs working over the network, some websites say it should not be more than 20% for broadcast, below you will find a link that could be useful:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swtrafc.html
Also check the TAC answer on this link:
https://supportforums.cisco.com/t5/lan-switching-and-routing/storm-control-thresholds/td-p/707264
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hope it is useful
