03-03-2017 11:57 AM - edited 03-08-2019 09:36 AM
Hi all,
I have the error in subject, but I can see any log that tells me where the issue started, this is a Nexus 7000, is there any way I can find why the issue started?
Thanks.
Solved! Go to Solution.
03-03-2017 01:16 PM
Have a look at this link for more info:
https://supportforums.cisco.com/discussion/10801401/what-mean-stp-2-disputedetected
03-03-2017 01:16 PM
03-03-2017 04:05 PM
Hello Reza
Thanks for the link, with this information, I would like to know if MST will be an
03-03-2017 07:48 PM
MST is used widely and should work fine.
