STP global port type inconsistent Nexus 9k
roger perkin
Level 2
Level 2
I have configured a VPC between a pair of Nexux 9Ks 93120TX Have enabled MST on both switches and now getting an inconsistency check error with global port type
Both switches are configured the same
spanning-tree port type edge bpduguard default
Still getting mis-match on consistency check?
Name Type Local Value Peer Value
Vlan to Vn-segment Map 1 No Relevant Maps No Relevant Maps
STP Mode 1 MST MST
STP Disabled 1 None None
STP MST Region Name 1 REGION-R REGION-R
STP MST Region Revision 1 31 31
STP MST Region Instance to 1
VLAN Mapping
STP Loopguard 1 Disabled Disabled
STP Bridge Assurance 1 Enabled Enabled
STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled,
BPDUFilter, Edge BPDUGuard Enabled Disable  <<  One side enabled one side disabled? Where
Diana Karolina Rojas
Hello Roger,
I recommend you to read this "We recommend that you set all the vPC peer link interfaces to the STP network port type so that Bridge Assurance is automatically enabled on all vPC peer links. We also recommend that you do not enable any of the STP enhancement features on VPC peer links." https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/layer2/502_n1_1m/b_Cisco_n5k_layer2_config_gd_rel_502_N1_1/Cisco_n5k_layer2_config_gd_rel_502_N1_1_chapter8.pdf
----Do not forget to rate useful post---
Thank you for your reply
they are set as Network
interface port-channel100
description VPC_PEER_LINK
switchport mode trunk
spanning-tree port type network
vpc peer-link
Try removing the "edge default" command and it should come up. Here is a link with more details.
http://www.itcertnotes.com/2011/06/impact-of-nx-os-spanng-port-type-edge.html
