how to config Firewall routing with Layer 2 Switch
OPRoger
i need your advice and help to configure routing in a proper way, the scenario is, i have one Layer 2 switch 2960G 24TCL connected to Firewall ASA 5520 and firewall connected to Router where i have two subnets for example 1.1.1.1(2MB) and 2.2.2.2(6MB).  there should be two vlans in access switch vlan 100 for server and vlan 102 for users. Vlan 102 should go 1.1.1.1 subnet and vlan 100 should go 2.2.2.2 subnet and vlan 100 and 102 both should communicate. how to achieve this, i really dont know what to do. Kindly assist.
Reza Sharifi
It may be easier to use the firewall to terminate both vlans by creating a sub-interface for each one (1.1.1.0 and 2.2.2.0) and have a layer-3 link between the firewall and the router. If you want to use the firewall in transparent mode, have a look at this link.
http://blog.alwaysthenetwork.com/tutorials/asa-bridge-groups/
