STP issue
Rajeev Ranjan
Hi Folks,
In my network there is STP issue. SW1 is connected to firewall and SW2..SW2 is connected to SW3. We didnt change the priority.SW3 becomes root bridge as it has lower MAC address.can you tell me how the data flow if SW1 wants to communicate with firewall. whats the role of STP in this scenario?there is no redundant link.
Jon Marshall
Not clear what you mean by data flow. Do you mean data going through SW1 or SW1 talking to the firewall itself.
Either way, if the mac-address for the firewall interface is in the mac-address table on SW1 and the data is coming from the same vlan then the traffic will be sent directly from SW1 to the firewall. If the data is in a different vlan then it would need to be routed onto the correct vlan then sent to the firewall.
On a more general note having a switch as a root switch for a vlan does not mean all traffic for that vlan must go via the root bridge. STP elects a root bridge as central point and then works out a loop free topology within the network. But that doesn't mean that all traffic must pass through it.
Jon
